#1 |
Vag Inspector
![]() Join Date: Jan 2008
Bike: 250R, 1000
Uploads: 0
Installed a set of 6000k's a while back and though I'd share the results. I'm not one for snapping pics unless there are
involved but I took a couple anyways.The ballast were slim and everything looked well constructed. The bulbs were adequately protected for shipping. ![]() Didn't take any pics of the install since it basically mirrors the instructions except for the placement of the ballasts. Ended up mounting them under the intake tubes in the front portion of the upper fairing. The install was pretty straight forward and was done without removing any bodywork. I did remove the steering damper though to provide more room to work on the Hi beam. The kit was plug & play and went together easily. The only exception noted was that the Hi bulb accepts a receptacle plug with 3 catches. But, the plug coming off the ballast had 4 catches. 5 seconds with a file took care of the pesky extra plastic catch. Before: Lowbeam with a Silverstar bulb ![]() After: Low with 6000k ![]() The camera distorted the coloring a bit. I have since adjusted the beam slightly to the left and down a little. The distance at which highway signs, lic. plates and cop car decals light up at night is pretty amazing. Overall, the biggest benefit is the additional safety due to the increased visibility the bike has become to other vehicles. Its hard to miss those lights in either daytime or nightime.
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. I fooled Plastic Cup Politics into a reach around |
#2 |
![]() Join Date: Jun 2008
Bike: 07 GSXR 750
Uploads: 0
Is there an adjustment for my k7 750 for left to right? I think I can only do up and down
#3 |
Lovin Life
![]() ![]() Join Date: Oct 2007
Bike: 07 R1, 05 V-Rod, YZ450F
Uploads: 96
Sweet, big improvement it looks like
I had some issues with my son so I have been delayed in putting mine on yet... hopefully this weekend.
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#4 |
Vag Inspector
Bike: 250R, 1000
Uploads: 0
assuming yours is set up like mine the adjuster on the left hand side is for horizontal and right side is vertical
__________________
#5 | ||
Come at me brah!
![]() ![]() Join Date: Jan 2008
Bike: Schwinn 18 speed
Uploads: 0
![]() Quote:
Yep, that's how they all are
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Quote:
#6 |
Bike: 2008 Honda CBR 1000RR
Uploads: 0
Wow, they look like a BIG improvement. So do you like them now? You didn't seem all that sure before.
__________________
#7 | |
Vag Inspector
Bike: 250R, 1000
Uploads: 0
Quote:
If your bike was ever rideable you would see them.
__________________
#8 | |
Uploads: 0
Quote:
I don't even want to think about my bike. I am getting sick just from the thought of what this is going to cost in labor alone. I am going on the second DAY of labor charges. 45 bucks every half hour. I think I am going to be sick.
__________________
#9 |
Bike: Insert Bike Here
Uploads: 0
Damn, the difference between the two lights is crazy! You're whole garage is lit up now!! When I decide on what bike to get I definately have to check these lights out.
Would you recommend this lighting system? From your post it seems that is it pretty self explanatory to install. Cheers |
#10 | |
Vag Inspector
Bike: 250R, 1000
Uploads: 0
Quote:
The installation is really easy with just the basic mechanical skills. Basically, its just changing bulbs and routing and hiding wires. 1OFF's product appears to be quality built and has been problem free for the last 2 weeks. They also provide a limited warranty which a lot of HID vendors may not. Actually, what surprised me the most about 1OFF was their customer service follow-up. The day my kit was delivered I received an email from Jose confirming my delivery and providing GSXR installation instructions. About a week later received another email from a sales manager inquiring whether I was satisfied with the product.
__________________
#11 | |
![]() Join Date: Apr 2008
Bike: k5 AMA Jordan Suzuki
Uploads: 0
Quote:
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. I won't buy a lady a watch because the time is on the STOVE!!! |
#12 |
Lovin Life
Uploads: 96
Top quality stuff imo... my are set to be installed in the next day or so... i will take soem pics like you did with a before and after.
__________________
#13 | |
Vag Inspector
Bike: 250R, 1000
Uploads: 0
Quote:
I've been looking at retrofitting some HID profectors from a Acura TSX in to take full advantage of the HIDs. Maybe a winter project?
__________________
#14 |
Lovin Life
Uploads: 96
Ya that might be sweet.... lucky for me I already have the projectors so I will report back on how much improvement it makes for me.
__________________
#15 |
Vag Inspector
Bike: 250R, 1000
Uploads: 0
Random daytime pic..Courtesy of Pat
__________________
#16 |
Bike: 2006 GSX-R1000
Uploads: 0
Honda jacket? wtf?!?!?1
__________________
#17 |
Site Sponsor
![]() Join Date: Jun 2009
Uploads: 0
That is an awesome pic of the lights DB! mind if l use it in our site?? great to hear you are loving them
![]() Jose 1 OFF Team |
#18 | |
Vag Inspector
Bike: 250R, 1000
Uploads: 0
Quote:
go ahead
__________________
#19 |
Uploads: 0
Were you high beams on or just your low beams?
__________________
#20 |
Vag Inspector
Bike: 250R, 1000
Uploads: 0
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1/4 throttle install | madmilar | General Bike Discussion | 2 | 05-30-2009 07:09 PM |
| I think I need Jer to help me install . . . . . | diddy2003 | General Bike Discussion | 16 | 05-04-2009 08:13 AM |
| windscreen install | B88BB8B | General Bike Discussion | 9 | 11-28-2008 04:01 PM |
| WooHoo! Just finished my R-55 & PC3 Install! | CWL | General Bike Discussion | 26 | 10-13-2008 03:22 PM |
| Bazzaz Install | motomummy | General Bike Discussion | 21 | 09-30-2008 10:17 PM |
