#1
Apr 15, 2008
i cant seem to find what i need could somebody tell me the torque specs for the triple tree and the front axle?
im putting my forks back in tomorrow and need the number so i dont wreck nothing
thanks guys
#2
Apr 15, 2008
front axle: 72.5 ftlbs
front axle pinch bolts: 16.5 ftlbs
brake caliper bolts: 28 ftlbs
clip on pinch bolts: 16.5 ftlbs
lower triple tree pinch bolts: 16.5 ftlbs
upper triple tree pinch bolts: 16.5 ftlbs
#3
Apr 16, 2008
thanks dude you rule
#4
Apr 16, 2008
front axle: tight ftlbs
front axle pinch bolts: Snug ftlbs
brake caliper bolts: semi tight ftlbs
clip on pinch bolts: snug ftlbs
lower triple tree pinch bolts: snug ftlbs
upper triple tree pinch bolts: snug ftlbs
#5
Apr 16, 2008
I always thought the tightness of bolts was gauged by the number of farts you do when your doing them up..
#6
Apr 16, 2008
i use this method as well
#7
Apr 16, 2008
I use the method that has a ratchet that makes clicken noises
I dont know if its the right clicken noise or the wrong clicken noise, I just know that it makes clicken noise
#8
Apr 16, 2008
TIGHTENING TORQUE
ENGINE
ITEM N?m kgf-m lb-ft
Exhaust pipe bolt 23 2.3 16.5
Muffler connecting bolt 23 2.3 16.5
Muffler mounting bolt 25 2.5 18.0
Muffler chamber bracket bolt 25 2.5 18.0
Muffler chamber mounting bolt 23 2.3 16.5
Muffler joint nut 25 2.5 18.0
Speed sensor rotor bolt 25 2.5 18.0
Speed sensor bolt 6.5 0.65 4.7
Engine sprocket nut 115 11.5 83.0
Engine mounting bolt and nut (M: 10) Bolt 55 5.5 40.0
(M: 10) Nut 75 7.5 54.0
Engine mounting thrust adjuster 23 2.3 16.5
Engine mounting thrust adjuster lock-nut 45 4.5 32.5
Engine mounting pinch bolt 23 2.3 16.5
Cylinder head cover bolt 14 1.4 10.0
Spark plug 11 1.1 8.0
Cam chain guide No. 1 bolt 23 2.3 16.5
Camshaft journal holder bolt 10 1.0 7.0
Cam chain tension adjuster cap bolt 23 2.3 16.5
Cam chain tension adjuster mounting bolt 10 1.0 7.0
Cam chain tensioner bolt 23 2.3 16.5
Cylinder head bolt
(M: 10)
Step 1/step 3 31 3.1 22.5
Final step 60?
(M: 6) 10 1.0 7.0
PAIR reed valve cover bolt 10 1.0 7.0
Water jacket plug 9.5 0.95 6.9
Water inlet cover bolt 10 1.0 7.0
Clutch cover bolt 10 1.0 7.0
Clutch sleeve hub nut 95 9.5 68.5
Clutch spring set bolt 10 1.0 7.0
Clutch lifter adjuster lock-nut 23 2.3 16.5
Starter clutch cover bolt 10 1.0 7.0
Starter idle gear cover bolt 10 1.0 7.0
Valve timing inspection plug 11 1.1 8.0
Starter clutch bolt 55 5.5 40.0
Generator cover bolt 10 1.0 7.0
Generator rotor bolt 120 12.0 87.0
Generator stator set bolt 11 1.1 8.0
Gearshift cam stopper bolt 10 1.0 7.0
Gearshift cam stopper plate bolt 13 1.3 9.5
Gearshift fork shaft retainer bolt 10 1.0 7.0
Gear position switch bolt 6.5 0.65 4.7
Oil pressure switch 14 1.4 10.0
Oil filter 20 2.0 14.5
10-46 SERVICING INFORMATION
FI SYSTEM AND INTAKE AIR SYSTEM
COOLING SYSTEM
Crankcase bolt
(M: 6)
(Initial) 6 0.6 4.5
(Final) 11 1.1 8.0
(M: 8)
(Initial) 15 1.5 11.0
(Final) 26 2.6 19.0
Crankshaft journal bolt
(M: 9)
(Initial) 18 1.8 13.0
(Final) 50?
Oil gallery plug (M: 6) 10 1.0 7.0
(M: 8) 18 1.8 13.0
(M: 10) 18 1.8 13.0
(M: 16) 35 3.5 25.5
Oil drain plug 23 2.3 16.5
Piston cooling oil jet bolt 10 1.0 7.0
Oil pump mounting bolt 10 1.0 7.0
Conrod bearing cap bolt (Initial) 37 3.7 27.0
(Final) 60? (1/6 turn)
Bearing retainer screw 10 1.0 7.0
Breather cover bolt 10 1.0 7.0
Oil strainer bolt 11 1.1 8.0
Oil pan bolt 10 1.0 7.0
Oil cooler mounting bolt 10 1.0 7.0
Oil cooler union bolt 10 1.0 7.0
Water bypass union 12 1.2 8.5
Starter motor mounting bolt 6 0.6 4.3
CMP sensor mounting bolt 10 1.0 7.0
CKP sensor mounting bolt 8 0.8 6.0
IAT sensor mounting screw 3 0.3 2.0
Fuel delivery pipe mounting screw 3.5 0.35 2.5
Fuel pump mounting bolt 10 1.0 7.0
TPS and STPS mounting screw 3.5 0.35 2.5
EXCVA mounting bolt 10 1.0 7.0
EXCVA pulley mounting bolt 5 0.5 3.5
Impeller securing bolt 8 0.8 6.0
Water pump cover screw 5 0.5 3.5
Water pump mounting bolt 10 1.0 7.0
Cooling fan mounting bolt 8 0.8 6.0
ECT sensor 18 1.8 13.0
Thermostat cover bolt 10 1.0 7.0
Thermostat air bleeder bolt 6 0.6 4.5
SERVICING INFORMATION 10-47
CHASSIS
Steering stem head nut 90 9.0 65.0
Steering stem lock-nut 80 8.0 58.0
Steering damper bolt and nut 23 2.3 16.5
Front fork upper clamp bolt 23 2.3 16.5
Front fork lower clamp bolt 23 2.3 16.5
Front fork cap bolt 23 2.3 16.5
Front fork inner rod lock-nut 15 1.5 11.0
Front fork damper rod bolt 23 2.3 16.5
Front axle bolt 100 10.0 72.5
Front axle pinch bolt 23 2.3 16.5
Handlebar clamp bolt 23 2.3 16.5
Front brake master cylinder mounting bolt 10 1.0 7.0
Front brake caliper mounting bolt 39 3.9 28.0
Front brake caliper housing bolt 22 2.2 16.0
Front brake pad mounting pin 16 1.6 11.5
Brake hose union bolt 23 2.3 16.5
Clutch lever holder mounting bolt 10 1.0 7.0
Air bleeder valve (Front and Rear brake caliper) 7.5 0.75 5.5
Air breeder valve (Front master cylinder) 6.0 0.6 4.5
Air breeder valve (Clutch release cylinder) 6.0 0.6 4.5
Brake disc bolt (Front) 23 2.3 16.5
Brake disc bolt (Rear) 35 3.5 25.5
Rear brake caliper mounting bolt 18 1.8 13.0
Rear brake caliper sliding pin 33 3.3 24.0
Rear brake pad mounting pin 16 1.6 11.5
Rear brake master cylinder mounting bolt 10 1.0 7.0
Rear brake master cylinder rod lock-nut 18 1.8 13.0
Front footrest bracket mounting bolt 23 2.3 16.5
Swingarm pivot shaft 15 1.5 11.0
Swingarm pivot nut 100 10.0 72.5
Swingarm pivot lock-nut 90 9.0 65.0
Swingarm pivot boss nut 65 6.5 47.0
Cushion lever mounting nut 98 9.8 71.0
Cushion rod nut (Front side) 98 9.8 71.0
Cushion rod nut (Rear side) 78 7.8 56.5
Rear shock absorber mounting bolt and nut
(Upper and Lower) 50 5.0 36.0
Rear axle nut 100 10.0 72.5
Rear sprocket nut 60 6.0 43.5
Side-stand mounting bracket bolt 95 9.5 68.5
Cowling brace bolt and nut 23 2.3 16.5
Rear shock absorber bracket nut 115 11.5 83.0
Seat rail bolt 50 5.0 36.0
Rear view mirror nut 10 1.0 7.0
10-48 SERVICING INFORMATION
TIGHTENING TORQUE CHART
For other nuts and bolts not listed in the preceding page, refer to this chart:
Bolt Diameter
(mm)
Conventional or ?4? marked bolt ?7? marked bolt
N?m kgf-m lb-ft N?m kgf-m lb-ft
4 1.5 0.15 1.0 2.3 0.23 1.5
5 3 0.3 2.0 4.5 0.45 3.0
6 5.5 0.55 4.0 10 1.0 7.0
8 13 1.3 9.5 23 2.3 16.5
10 29 2.9 21.0 50 5.0 36.0
12 45 4.5 32.5 85 8.5 61.5
14 65 6.5 47.0 135 13.5 97.5
16 105 10.5 76.0 210 21.0 152.0
18 160 16.0 115.5 240 24.0 173.5
#9
Apr 16, 2008
I would always recommend it for internal engine parts, and i would ALWAYS recommend it for others for liability issues. but I myself will never do it as 90% of all bolts are common sense imo and going by their specs is a false sense of security. I do what I think is good and check things often. I've seen people using specs have issues, but no bolt i tighten comes out and rarely is anything overtightened. I don't even use loctite on many parts because my arm is so calibrated
#10
Apr 17, 2008
well would you agree that my front suspension is a critical part of my motorcycle and deserves special attention?? other than that i agree . BUT if i go down i want it to be my own dumb fault not because a part failed on my bike
#11
Apr 17, 2008
theres no critical bolts on your front end, as long as the bolts are tight they arent going anywhere.
I've never torque'd one of those bolts either
#12
Apr 17, 2008
just something that was preached to me ever since i was young since my grandpa worked in the development department for bilstein suspension in Germany. my dad would not even let me ride my first motorcycle if the tires and suspension weren't absolute immaculate
gues its in my blood
#13
Apr 17, 2008
The only things I can see being tightened to spec is internal parts
