When you install a full exhaust on the 07-08 GSXR 1000 and you pull the exup/set cables and all that crap out you'll have your ecu throw a code. You need to follow the directions that are found in the below .pdf to disable it. These directions are from yoshimura and you pull a wire out of your ecu harness and full directions can be found here at this link.
http://www.motomummy.com/yoshfull.pdf
