Specs
Engine:996, four-stroke, liquid cooled, 90 degree V-Twin, DOHC, 8-valves, TSCC
Bore Stroke:98.0 x 66.0mm
Compression Ratio:11.6:1
Fuel System:Fuel Injection
Lubrication:Wet Sump
Ignition
igital/Transistorized
Transmission:6-Speed
Final Drive:530 Chain
Overall Length:2085mm (82.1 in.)
Overall Width:745mm (29.3 in.)
Overall Height:1170mm (46.1 in.)
Seat Height:800mm (31.5 in.)
Ground Clearance:150mm (5.9 in.)
Wheelbase:1430mm (56.3 in.)
Dry Weight:186kg (410 lbs.) 187kg (412 lbs.) CA model
Suspension Front:Telescopic, cartridge-type, adjustable preload, adjustable compression & rebound damping
Suspension Rear:Link-type, adjustable preload, adjustable compression & rebound damping
Brakes Front
ual hydraulic disc
Brakes Rear:Single hydraulic disc
Tires Front:120/70 ZR-17
Tires Rear:180/55 ZR-17
Fuel Tank Capacity:17 liter (4.5 gal.) 16 liter (4.2 gal.) CA model
Color:Black, Blue
Ignition
Brakes Front
Color:Black, Blue
