Specs
Engine:599cc,4-stroke,four-cylinder, liquid-cooled, DOHC, 16-valve*
Bore Stroke:67.0 x 42.5mm
Compression Ratio:12.8:1
Fuel System:Fuel Injection
Lubrication:Wet Sump
Ignition
igital/transistorized
Transmission:6-speed, constant mesh
Final Drive:#525 chain
Overall Length:2040mm (80.3 in.)
Overall Width:715mm (28.1 in.)
Overall Height:1125mm (44.3 in.)
Seat Height:810mm (31.9 in.)
Ground Clearance:130mm (5.1 in.)
Wheelbase:1400mm (55.1 in.)
Dry Weight:163 kg (359 lbs)
Suspension Front:Cartridge-type, coil spring, fully adjustable spring preload, rebound and compression damping
Suspension Rear:Link-type, gas/oil damped, fully adjustable spring preload, 2-way adjustable compression and rebound damping
Brakes Front
ual hydraulic disc
Brakes Rear:Single hydraulic disc
Tires Front:120/70-ZR-17
Tires Rear:180/55-ZR-17
Fuel Tank Capacity:17.0 liter
Color:Blue/White, Silver/Yellow, White/Silver, Black/Matte Black
Ignition
Brakes Front
