Specs
Engine:645 cc, four-stroke, liquid cooled, 90� V-twin, DOHC, 8-valves, TSCC
Bore Stroke:81.0 x 62.6 mm
Compression Ratio:11.5:1
Fuel System:Fuel Injection
Lubrication:Wet Sump
Ignition
igital/Transistorized
Transmission:6-speed
Final Drive:#525 chain
Overall Length:2085 mm (82.1 in.)
Overall Width:730 mm (28.7 in.)
Overall Height:1170 mm (46.1 in.)
Seat Height:800 mm (31.5 in.)
Ground Clearance:155 mm (6.1 in.)
Wheelbase:1430 mm (56.3 in.)
Dry Weight:178kg (391 lbs.)
Suspension Front:Telescopic, coil spring, oil damped, fully adjustable preload
Suspension Rear:Link-type, 7-way adjustable spring preload
Brakes Front
ual hydraulic disc
Brakes Rear:Single hydraulic disc
Tires Front:120/60-ZR17
Tires Rear:160/60-ZR17
Fuel Tank
Capacity:17 liter (4.5 gal.) 16 liter (4.2 gal.) CA model
Color:Blue, Gray
Ignition
Brakes Front
Fuel Tank
Color:Blue, Gray
