1 - 20 of 20 Posts
its easy if you dont mess up like i did the first time... dumb ass me...
it only takes like 5 minutes... unless you unscrew the screw that your not supposed to unscrew. (how many times can i use the word screw in one sentence)
not for me... i like the looks of the halos but i've torn apart many head lights and one thing i've learned is that no matter how we'll you seal em back up they will eventually collect moisture inside. I just went with an HID kit. Love it, wouldnt change it for nothin.
I need to buy another kit............Found a place that sells 2 bulbs, 2 ballasts for $99 if you want slim ballasts its $125 total
I bought my origional kit from www.xenonrider.com but I ended up removing it. The place I found that has a deal on 2 bulb and 2 ballasts is www.starrotors.com/bulbs
EDIT: In case you're wondering, I LOVED the HID's, but was having problems out of them. From the factory, both my bulbs run all the time, flip the high beam and the high beam get's brighter. The kit I bought I wired up to where when the highbeam was off, the top bulb was completly off and would come on when you activated the high beam. One day I was messing around with it with the key on and the bike off and every time I hit the high beam to turn the bulb on, it would flicker....then when it lit, the fuel pump would cycle again like you turned the kill switch from on to off to on again. :Weird It did it everytime I hit it and I didn't want it messing anything up, so I pulled them
Discussion Starter · #17 ·
Another kit? The claims are that the things last for like the lifetime of the bike! Should'a figured it sounded to good to be true
. Anyways, is there a lot of splicing or anything involved in the installation? Does it come with instructions :biggrin?
1 - 20 of 20 Posts
