Traxxions standard fork fluid is the Maxima Racing Synthetic in 7.5 weight. Might be a little heavy with stock valving unless you are already running in the outer range of your adjustments.Captain Squid said:Damn I just had mine done 2 weeks ago at traxxion dynamics and he told me what oil he put in it, but I forgot lol
I just changed forks seals out in a K6 1000 a few weeks ago...seems like thay all start to leak very early
I've got the axxion valving/springs in it as wellgsxr_cbr said:Traxxions standard fork fluid is the Maxima Racing Synthetic in 7.5 weight. Might be a little heavy with stock valving unless you are already running in the outer range of your adjustments.
Since you are looking to keep this a street bike, I would change out the fork seals, put new springs in it(for your weight), use stock valves, stock fluid and when it comes time to change the fluid again then change out the valves and go to a different fluid.elkbow said:thanks, i may just put a valve kit in, but will probably stick with stock oil...not looking to go to the track, so will stick close to stock...maybe if i pick up a K8 will change to all the guts
You would be amazed at the weight the stock springs are for. They are more likely to fit a guy my size, 150, than one your size... not tryin to say your fat or anything.. just sayin:biggrin.elkbow said:yeah, from what i was thinking, the stock fork springs should be pretty good for my weight, 180, so just getting the seals and oil changed should be fine for most stuff, I haven't really had a problem with the stock setup, i ride hard and it works fine...the valving because i have a racetech valve kit sitting here for some time, just didn't really see the need to put it in...
Earlier you stated that you weighed in the 180 range. That weight would put you at the .925 to .95 area.elkbow said:i was trying to figure out the spring rates and what I needed, i thought they were on the stiff side and not soft side according to specs, they are i believe .95 stock and it is recommended I thought after i checked that i go with around a .91...
Gottcha about the spring rate! I would say stay at the .95 rate, put in your valves(for smoother operation) and do a stock oil along with your fork seals. At the .95 rate you will be able to use the extra for a passenger, if you happen to ride with one often and you could adjust it to the soft side if you dont ride with a passenger often to get rid of some of the stiffness. I would check the springs, while you have them apart, to verify that the springs are actually .95's... just to be safe.elkbow said:i used an online calculator for spring rate, which does both weight of the bike and rider to calculate the 'ideal' fork spring weight, not that you can get that weight, as it does come in the .05 incriments, what i was getting at, i weigh 180, the 'ideal' setup says a .91x spring, and stock i believe is .95....so do you go down to .90 or stay at the stock .95....i would think i'm okay...
the sag, etc. i have set with a friend doing measurements for me, it is all setup ok, like i said, it does well on the road with hard riding, i'm rebuilding the forks as one of the seals is leaking, so was looking at anything else i would do while i'm at it....not sure if the racetech gold valve kit will help any or if i should even put it in....
i don't want to do too much, i may pick up an 08, got the money, just haven't decided...
