1 - 1 of 1 Posts
· Premium Member
M328-000 Zero Map 28 KB
M328-001 Stock exhaust, Stock or aftermarket air filter 29 KB
M328-002 Ti-Force full exhaust, Stock or aftermarket air filter 29 KB
M328-003 Micron full exhaust, Stock or aftermarket air filter 96 KB
M328-004 Leo Vince full exhaust, Stock or aftermarket air filter 96 KB
M328-005 Akrapovic full exhaust, Stock or aftermarket air filter 96 KB
M328-006 M4 full exhaust, Stock or aftermarket air filter 96 KB
M328-007 Orient Express slip-on exhaust, Stock or aftermarket air filter 96 KB
M328-008 Hindle full hi mount slip-on exhaust, Stock or aftermarket air filter 96 KB
M328-009 Hindle Mega slip-on exhaust, Stock or aftermarket air filter 96 KB
M328-010 Hindle Mega full exhaust, Stock or aftermarket air filter 96 KB
M328-012 Arrow slip-on exhaust (with mid-pipe), Stock or aftermarket air filter 96 KB
M328-013 Two Brothers slip on exhaust, Stock or aftermarket air filter 96 KB
M328-014 Arrow full competition exhaust, Stock or aftermarket air filter 96 KB
M328-016 Yoshimura R-55 full exhaust , Stock or aftermarket air filter 96 KB M328-501 European model Stock exhaust, Stock air filter, O2 sensor disconnected, Pin 30, black ECU connector disconnected to disable FI light 29 KB
M328-502 European model-Arrow Full racing Exhaust - Cat. Removed, Stock or aftermarket air filter, Pin 30 on BLACK ECU connector disconnected 29 KB
M328-503 European model-Leovince Full racing Exhaust - Cat. Removed, Stock or aftermarket air filter, Pin 30 on BLACK ECU connector disconnected 29 KB
M328-504 European model-Leovince racing Slip On - Cat. removed - S.E.T. valve in place, Stock or aftermarket air filter 29 KB
M328-505 European model- MIVV Round Carbon Slip On CE Approved (Db-Killer installed), Cat. removed - S.E.T. valve in place, Stock or aftermarket air filter 29 KB
M328-506 European model-MIVV racing Slip On - Cat. removed - S.E.T. valve in place, Stock or aftermarket air filter 29 KB
M328-507 European model-MIVV High CONICO Slip On CE Approved , Db-Killer installed), Cat. removed - S.E.T. valve in place, Stock or aftermarket air filter 29 KB
M328-508 European model-MIVV CONICO ALTO racing Slip On - Cat. removed - S.E.T. valve in place, Stock or aftermarket air filter 29 KB
M328-509 European Model-Akrapovic Full Racing Exhaust - Cat. removed, Stock or aftermarket air filter, Pin 30 on BLACK ECU connector disconnected 96 KB
M328-510 European model-Yoshimura GP Evo CE approved Slip On with catalyzer, Stock or aftermarket air filter, O2 sensor disconnected, Pin 30 on BLACK ECU connector disconnected 96 KB
M328-511 European model-G & G bike CE approved slip on (Db Killer installed) with catalyzer, Stock or aftermarket air filter, O2 sensor disconnected, Pin 30 on BLACK ECU connector disconnected 96 KB
M328-512 European Model-G&G Bike racing Slip On - Cat. removed - S.E.T. valve in place, Stock or aftermarket air filter, O2 sensor disconnected, Pin 30 on BLACK ECU connector disconnected 96 KB
M328-513 European model, Micron full exhaust, Stock air filter, O2 sensor disconnected, Pin 30, black ECU connector disconnected to disable FI light 96 KB
M328-514 European model, Micron slip-on exhaust, Stock air filter, O2 sensor disconnected, Pin 30, black ECU connector disconnected to disable FI light 96 KB
M328-515 European model, Micron slip-on exhaust with baffle, Stock air filter, O2 sensor disconnected, Pin 30, black ECU connector disconnected to disable FI light 96 KB
M328-516 European model, Yoshimura GP Evo slip-on exhaust, Stock air filter, O2 sensor disconnected, Pin 30, black ECU connector disconnected to disable FI light 96 KB
M328-517 European Model, Arata Full Racing Exhaust, Stock or aftermarket air filter, Pin 30 on BLACK ECU connector disconnected 96 KB
M328-ALL All Maps 124 KB
1 - 1 of 1 Posts
