1 - 16 of 16 Posts
Twice now someone has posted a link to a pic hosted via GFN and it has required me to log in a second time to view it.
Attachments in threads seem to be easily visible. No idea what's going on here.
· Premium Member
What address are you using? if you are using http://gixxer-forum.net then you will have this issue... you need to use http://www.gixxer-forum.net
I will create a re-direct rule for the site to redirect everyone to use the www.
The reason is it creates a different cookie for non www. then when you try to go to an image that is stored in the file system under www. it says your not logged in.
Let me know if this is it?
1 - 16 of 16 Posts
