If you clip ons arent visibly bent then.....
Your clip ons probably arent tweaked, your forks are. Happens all the time when we have low speed get offs at the track. You need to loosen up the axle, pinch bolts and lower triple bolts then bounce the front end up and down real hard. They will straighten right out. Dont losen them too far, just enough that things can move. They are under tension right now because they are tweaked. Bounce it, tighten everything back up and check it. If it's still a little out do it again.
