water injection will keep the engine safer unless you use the wi to allow more boost HAHAH that's what i did. biggest thing is keeping the air temps down which wi will help. A side mounter ic would help a ton also, but on a bike it's hard to fit a very efficient one.
the exhaust temps and knocking are the most important things. just remember that even if you tune it on a dyno that doesn't mean that it's 100% as ambient air temps make a huge diff with a turbo. If i were you i would look at the motty to tune it as it tunes as you goes, but changes a hard coded map where the bazzaz just stores the info then you have to program it to change the map. Motty's software might just be what you need. I would talk to motty about it. i know in my car a nice 40 degree air temp made me need to lower boost or add more fuel if it got colder and more dense.
