1 - 1 of 1 Posts
2003 Suzuki Gxsr 600.
(RR is on the left side rear) as soon as the key is turned to accessory , the main fuse blows .
Hey guys, I’ve been through all the forums about this issue and I’ve seen that all lead to the RR.
Heres the thing, the rr connects to a plug, and that plug connects to the chassis ground .
I disconnected the rr and connected the plug that connects to the ground and the Main Fuse blows.
If I disconnect that connector then the main fuse does not blow and I have 12 volts on my wires .
I do not see any shorts at all, I even disconnected all connectors . But as soon as that ground is plugged in … main fuse goes out.
if anyone has any suggestions :/
1 - 1 of 1 Posts
