Hi everyone, New to the forum. I just found it while trying to look for a resolution to an issue I am having with my 2009 GZ250. It had been setting for a long time. I got a new battery, Drained the old gas, did an oil and filter change. I got it to run but I could not put any throttle to it with out it dying. It would idle. I pulled the Carb and cleaned it. The choke cable broke on me so for now till the new one gets here I have put in the Pin and spring to keep the Choke off. I can crank it but it has a very slow idle. If I apply just a little gas it cuts off. If I remove the air filter and spray some starter fluid into the throat of the carb it cuts off. If I hammer down on the throttle it sputters a lot then finally starts revving up. As long as I keep 3/4 to full throttle I can get it to run under throttle. If I let go it goes back to a slow idle. Anywhere in between and it dies. Throttle response is also very slow. Thanks in advance for any information or clues you can provide.
