1 - 20 of 46 Posts
well was just curious if any one has ever had a 520 conversion ( chain ) break......i am looking to get one of these but, not to sure about it, so i was thinking maybe some of you guys can enlighten me on this subject
can it hold the the power ( 190 + hp )
thanks:biggrin
Biga said:
Yes it can
I run 520 kit on my bike, never had any problems, plus it smaller then the stock obviously, and therefore less rotating mass, which is
thats why i was looking into it...they say approx 4 lbs
what setup do you have sprockets / chain ( manufacturer )
thanks bigs:biggrin
Premium Member
I used Renthal sprockets, Not going to lie to you, but I have completely forgot what chain brand I put on. It was 4yrs ago now
My mind is going
I did put on a never ending chain
onepusher said:
You will be fine with a 520 conversion. I have a DID chain with vortex rear sproket and no problems. Look at Finally got my white k8 post.
yes but, you have yet to twist the throttle with the 190 hp...thats what i'm thinking about doing from carpenter race engines..let us know when you twist the throttle.....
by the way nice bike too.....:biggrin
over 200rwhp then go with 530. The sidewinder sprocket is the same as a stealth, 100% the same thing and made by www.supersprox.com. The erv3 is fine for a 600/750, but for a 1000cc bike i would do an ek mvxz or rk gxw chain as they are much stronger then the erv3. In fact DID doesn't even recommend their chain for a 1000cc bike where ek and rk do.
520 kits are fine unless you stunt a lot or are coming up on 200rwhp then I would stick with 530. EK mvxz is what we use our on two 1000cc bikes because it's the strongest 520 chain on the market. never had a problem. driven sprockets and the ek mvxz.
Then my bone-stock K6 should be okay? She has well over 20k+ miles on the original chain and sprockets (religious about cleaning, lubing and adjustments). Thinking of ordering a gold 520 chain and Renthals f/r, with a 16t front tooth size. 80% street use, 20% trackdays.
How's that sound?
yes you would be fine. Just make sure you get hard anodized sprockets and renthals are hard anodized along with everything we sell. I won't even sell a sprocket if it's not hard anodized. As for the chain just make sure you get an rk gxw or ek mvxz would be my opinion. Two of the best chains on the market for the 1000cc guys. We won't sell the cheaper chains as those are what save you a little up front but if you have a problem you'll be paying dearly down the line. Those two chains are the best by those manufacturers and are plenty strong.
A lot of info about chain kits can be found here as well.
http://www.gixxer-forum.net/forum/showthread.php?t=70
Site Supporter
I've been running the same DID/AFAM 520 kit for two years now and it's just now starting to stretch!!!! I don't push over 165 at the rear wheel so I feel really safe with it. Only reason I'm going to a new chain and sprockets is to go up a couple in the rear!!
Discussion Starter · #15 ·
well if i do head and cams puts me at about 190 rwhp...maybe give or take a few.....
would you do it, 520 conversion that is
i not sure which way i am gonna go ( as if i might not do the head & cams ) just thought i'd get some insight....
thanks guys
not sure if i wanna drop another $ 3,500 dollars
1 - 20 of 46 Posts
