07 Hayabusa rims will they fix any other GSXR's? Anybody know? Thanks.
You will need the spacers for it to work properly.. but yes it can be done.speedwasinvolved said:07 Hayabusa rims will they fix any other GSXR's? Anybody know? Thanks.
that works for the rear rim, the front rim of the busa is wider than the newer gsxr's and wont line up with the brake calipersslidewayz said:You will need the spacers for it to work properly.. but yes it can be done.
I have put Busa wheels on various older (01-03) gixxers before. I used the spacers from the busa.
I put a set of 04 Busa wheels on a 02 GSXR 750 and put a set of 01 Busa wheels on a 02 GSXR 1000 without having any problems of any sort. I just used the spacers off the Busa for the proper fitment in the rear. The fronts had no issues with rubbing or being misaligned.mpdgsxr1000 said:that works for the rear rim, the front rim of the busa is wider than the newer gsxr's and wont line up with the brake calipers
