1 - 20 of 31 Posts
I've read that the shift light comes disabled from the factory. How do you able it and set the shift light? I read the manual and tried to turn it on and set it but it's a lil confusing and I can't seem to get it working.
btw. I'm more a visual person. thanks
· Level 7 awesome
not sure how to do it on the K7's but I hope it's not like my 05 for ya. My 05 750 I can turn the key on and set it and it works fine till i turn the key off, then it erases it and it won't work till I re-program it
i dont remember which button it is but with the 750 you have to hold the button while turning on and the shift light should light up or something like that then you can adjust where you want it and how you want it to light up. hopefully this helps.
· Moderator
ya its a pain in the ass. I havent done it in a while. Its not the same Captain as on your bike. Its been a lil while since ive done it. when i get home ill do it and repost for yall.:dunnoat the moment i cant remember if its the top button or the bottom.
you can set it to either do a solid continuous light or a pulshing light once indicator passes desired(or preset) rpm. I like it to be in continuos. Flashing lights to me mean go faster:shock
· Certified Trackwhore
That's how mine is as well. And it's in memory until you adjust it. The owners manual tells you how to set it.
Discussion Starter · #11 ·
I GOT IT!!!! yea i'm happy I figure something out. hehe
This is done on a k7 1000. Sorry no pictures. I can take some if requested.
To set the shift light to either continuously on or blink and RPM setting. First:
Put your key in the ignition but don't turn.
Push and hold the selection button, then turn the key ignition on.
After everything loads up ( I let the cluster load up), push the adjust button to choose light on or light blink.
When you have it set to whichever you want, push the selection button again.
Now push the selection button again and the RPM needle will move.
To move the needle, push the adjust button (and keep pushing) to go to which RPM you want.
After you have it set, push the selection button.
And done.
I hope this helps
· But Could Your Network Work?
Hey Guys Iam new here to this site but long time rider, i have once question, I own a 2008 GSX-R 1000 and ive hade it since jan,08 and i cant figure out what the lil white light is for, the one when you turn the key and the lil white light turns on for 5secs and goes away. what is that light for and is there anyway to activate.???
· Brahptimus Prime
The only thing I can think of would be the shift light, and you can adjust it to turn on at any RPM you would like. Once your engine hits that RPM, the light will turn on telling you that you have reached it. Other than that I don't know what it would be, you could always try posting a picture of it. But I'm assuming that's what you are talking about.
I'll find the procedure for you online to set it, unless you have your owners manual handy by any chance
· Brahptimus Prime
(Courtesy of PurEvo)
"To set the shift light to either continuously on or blink and RPM setting:
First, Put your key in the ignition but don't turn.
After everything loads up, push the adjust button to choose light on or light blink.
After you have it set, push the selection button."
And that's it, Your shift light is set.
Yes the shift light, and thanks for the post
· Level 7 awesome
I knew you were good for something
· Zippy's My bitch
It's not looking like it has one
Compact instrument cluster includes analog tach, LCD speedometer, odometer/tripmeters, and temperature gauge, plus LCD clock and low fuel warning light
1 - 20 of 31 Posts
