1 - 2 of 2 Posts
Greetings!
I have a 2008 C90t that won't start. I took apart the starter button and kill switch and cleaned them. They needed it but that wasn't the issue.
In terms of the battery it seems there would be enough juice because if I jump the starter relay, the starter works fine. It seemed as if the relay was the bottleneck but after replacing it, I still had the same problem and noticed a F1 code. When I jumped the plug that the dealer uses the code on my dash read c00.
Since this problem began, I noticed that after flipping the kill switch to start, the sound is not the same. There's about a two second sound electrical noise that has been reduced to almost nothing. What is that noise or electrical transfer about?
Thank you in advance!
1 - 2 of 2 Posts
