Okay, I know one of them is for the oil check sight, but what is the lower one for? Anybody know?
Long_av8r said:. Here's the real answer...
"the dry clutch is derived from the race course for competition only, so when they produced those parts, the upper sight glass is used to measure oil with engines that have a dry sump oil pan set-up, and the lower sight glass is used for the stock oil pan set up, so it changes the oil level with a dry-sump compared to a regular set-up oil pan, do you get what I mean by a dry-sump? oil pan. So Suzuki mass produced one style of cover with two sight glasses instead of producing two different covers, it saves on manufacturing costs just to produce one style that can be used both ways. hope this helps."
It's up above you.rebellgixxer said:I read somewhere that it was for a quick oil check when racing.Instead of having to wait for the oil to sink all the way down,If the oil could be seen in the lower window there was enough oil in the engine.
I don't know how true this is but I will see if I can find the site where I saw the posting.I will post as soon as I find the link
Mike
Doh thats typical of me not seing the forest for the treesCaptain Squid said:It's up above you.to the forum BTW![]()
The dry sump oil pan was shallower hence the upper sight glass.xbacksideslider said:I get the explanation but I am confused. I would expect a dry sump set up to use the lower sight glass - a lower level, since more of the oil would be in the oil tank. Maybe the unidentified person who explains it got it switched when he says ". . . . the upper sight glass is used to measure oil with engines that have a dry sump oil pan set-up, and the lower sight glass is used for the stock oil pan set up . . . ." ?
